Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
3200 mile road trip and didn't notice it on mine....Still less than 1000 miles, driving at interstate speeds a whistling noise from drivers window occurs. Anybody else notice this? Is there a fix? Thanks.
One of my cars used to do that, my brother who is a body shop manager opened the drivers door then opened the window and proceeded to put his knee on the inside of the door and pulled the corner of the frame top and right or left depending which door, towards him thus tightening the gap between the frame and the rubber seal, it worked you could try that just be careful you don't pull too hard.Still less than 1000 miles, driving at interstate speeds a whistling noise from drivers window occurs. Anybody else notice this? Is there a fix? Thanks.
Nope that does sound like standard bodyshop practice. Gotta get things into place somehow, certainly beats a hammer."One of my cars used to do that, my brother who is a body shop manager opened the drivers door then opened the window and proceeded to put his knee on the inside of the door and pulled the corner of the frame top and right or left depending which door, towards him thus tightening the gap between the frame and the rubber seal, it worked you could try that just be careful you don't pull too hard."
Your joking right?
No."One of my cars used to do that, my brother who is a body shop manager opened the drivers door then opened the window and proceeded to put his knee on the inside of the door and pulled the corner of the frame top and right or left depending which door, towards him thus tightening the gap between the frame and the rubber seal, it worked you could try that just be careful you don't pull too hard."
Your joking right?
No, it worked a treat, just be very careful and do it a bit at a time."One of my cars used to do that, my brother who is a body shop manager opened the drivers door then opened the window and proceeded to put his knee on the inside of the door and pulled the corner of the frame top and right or left depending which door, towards him thus tightening the gap between the frame and the rubber seal, it worked you could try that just be careful you don't pull too hard."
Your joking right?
