What's your biggest gripe with the prelude?
Having put a dog cage on the back seat, the seats not returning from whence they came is driving me nuts every time I have to load the dog in.
Have you also found the lane assist 'sticky'? Like it alerts I've drifted too far left, yet resists me turning the wheel right to correct?
seats :
yes ...but at least they have a "alert" to pick "things" from the rear set when leaving :)
Yes, it's a two door, but isn't Honda proud of having clever seat solutions ? Grrrr.....
lane assist :
...let me switch left/right in mind ..but yes, it feels that, when the lane assists "alerts", it is keeping the actual distance at the same time, have to add some "force" to correct and clear the alert ... but its tricky to reproduce these effects in real life traffic
Hi,
after 2 months with my Prelude, here are my top ten of gripes....
(some of them seem only apply to european version)
- speed limit beeper at the first kilometer overspeed, threshold level menu not available in EU. I don't mind the flashing symbol, it's the beep...and it's no consolation that other manufacturers are worse ....
- missing "Walk Away Auto Lock"
- door handles do not fold out when approching the UNLOCKED car
- passenger mirror does not lower when parking reverse
- seat does not move to forward position when accessing back seat
- neither seat nor even seatback do return to its original position (my 3door civic had that feature 20 years ago...)
- traffic sign recognicion has room for improvement (e.g. some speed limits have a time frame (10pm to 6am)- the system recognizes the aditional sign, but not the content)
- lane assistant often intrusive (on wide lanes, it tries to keep you in the middle, even if there is plenty of distance to the borders, also annoying especially on towns, where one side of the street is used for parking and therefore lanes are aymetrical and not according to marking...
- the car does not memorize the last used drive mode (why allow an "individual mode" when not using it until changed?)
- there is an "App Installer" but no information about which Apps may be installed here (the dealer says"its may be for the future ..")
- lockking sensor on door handle picky - why not just implement a simple "close handle to lock"
to make it clear - i love the car, it was clear that i'll get the Prelude from the first info that its beeing revived....
and maybe i'm a bit picky switching from a Infiniti Q60, but Honda ...come on, you CAN do it better ...
greets
The doors opening after popping out are hit and miss, and the closing, a lot of times I touch the top marks and nothing happens, a bit disappointing really, I just close it with the key fob now most of the time, as far as the seats I find if I'm putting stuff on the back seat I just move the seat forward as far as it will go without moving the back bit, and that's usually enough to get things in without disturbing the back angle.
I'm unfortunately not very flexible so wrangling an uncooperative chihuahua into the back requires a full seat reset every time.
I’m a little confused. I get my dog on the front seat (she can jump up) and she steps on the center console and then into the back. No seat adjustment required. A chihuahua is too small even when starting from a front seat?
It's an enclosed box/cage, I have to lean into the back, open it, and place him inside it. ISOFIXed into the rear seats keeping the little guy secure and stops him making a mess.
Because they haven't unlocked yet. Once again: door handles popping out do not mean the door is already open. 🙄
But even when I put my hand under it and pull to open it doesn't even when I wait, it's around 50/50 whether it opens or not, and closing is the same, as I said I now find it easier to just use the key fob most of the time.
That does not sound right. If I give mine half a sec after touching the handle, it does unlock 99% of times. Maybe you should ask your dealer to check on it?
Thats does not sound right. If I give mine half a sec after touching the handle, it does unlock 99% of times. Maybe you should ask your dealer to check on it?
Where exactly are you touching the handle after they pop open?
I usually move my hand below the handle without any haste. Works 99% of the time. Before I was not aware that the car had not yet unlocked when popping the handles out, I moved my hand closely above/at same level with the handle. That, as I would estimate, did work for like 60% of the time.
Sounds like what I'm doing. I will try it your way tomorrow, thanks.
Try placing your fingertip in the hollow part underneath the handle. Works for me every time. 👍🏻
i think there are two major ways to pull the handle....from the side with one finger, or from below with one or more fingers.
Maybe, if pulling from below, with one finger, you do not have enough contact to the sensor and unlocking is not always initiated ?
I use the first one as it it feels more comfortable to me....works 99%....but you have to keep in mind that it takes about half a seconf from recognizing fingers intil the "clack" sound which indicates the unlocking....
When unlocking with key fob, there is (of course) no waiting ....
Due to its design, it bothers me a bit that I can't simply push it back and forth—in the CTR, you just have to shift into neutral—but maneuvering a hybrid like that is, unfortunately, a real hassle and overly complicated. You can't even back up a little with the door open when you want to look behind you for better visibility.
...yep...agree...also prefer the "old fashioned" stick for shifting ...you can use it blind... no need for changing positions of fingers and "searching" for the correct button.... still missing the "D" and pushing the "N" ......the buttons look sleek, but unfortunately my evolution is too slow to adapt to the button-only design :-)
I don't know how or why but is anyone else finding their car IS remember the previous mode they started in?
The DC converter that charges the 12V battery during operation doesn't seem to deliver the same kind of sustained, high-output charging as the traditional alternator found in internal combustion vehicles—could that be the case? And as a rule, I drive for at least 40–50 minutes per trip. Of course, the battery does get charged—eventually, one way or another. However, whenever I know the Prelude is going to sit idle for a week or two, I hook up my NOCO Genius 5 charger/maintainer; it invariably starts with a "bulk charge" phase—during which the unit gets quite warm and the LEDs flash red and orange—followed by the green LED appearing after about two hours, indicating a near-full charge, and finally a solid green light after roughly 20 hours, signifying that it has switched to maintenance mode. So, does the converter operate very, very efficiently?
I had my first flat battery incident yesterday, which was very unexpected as I had recently driven the car, but it had been left unused for just one day only, in my garage in the dark.
The suspicion is a camera may have activated and drained the battery over time but no evidence so far and the camera in question had been installed five months earlier and this was the first occasion to doubt it. There may be some other cause, possibly the car left in accessory mode, the jury is still out regarding the root cause.
A shout out to Carl at Fish Brothers Honda who came and rescued me as The AA Service engineer provided by Honda Roadside Assistance was unable to gain access to the cabin, despite us trying both manual keys contained in two fobs.
The AA and myself were baffled why the manual key would not open the driver's door in the absence of battery power. The usual trick involving an airbag was ineffective in trying to prise the door open enough to get a rod to the bonnet/hood release.
Carl gained access immediately much to the incredulity of myself and The AA and it involves a particular sequence, worthy of a masonic handshake with the door handle.
My advice for owners is have a practice at opening the drivers door with the manual key when your fob is out of range of the car, before you are ever in the situation of having a flat battery and need to open the door in anger!
