Does the Prelude use the same problematic LF engine that has bad head gaskets?
Interesting. Here in the UK...
'Regular' petrol/gas is 95 RON and has up to 10% renewable ethanol (E10).
'Premium' petrol/gas is 97 to 99 RON with up to 5% renewable ethanol (E5).
Honda UK say you can use either of these in the new Prelude but also states that 95 RON is the minimum. Here's the fuel flap label on my (UK) car...
This page is from the UK owner's manual. It says you can temporarily use 91 RON or higher, if 95 is not available. But it "...can cause metallic knocking noises in the engine" and using it long-term "..can lead to engine damage"...
What do the US/Canadian manuals say about fuel grade/quality? And if it's different to this UK version, why is it different?
When you say today, do you mean cars made in the last 3 months or so, as I picked mine up in early August, and it was ordered in June? I think they were supplied to order for the UK. It does seem odd that the Prelude is never mentioned in any of the gasket problem articles.
It is my assumption that Honda would use the most updated head gasket for current production. Only Honda really knows which VINs have what parts and when they started using those parts. Honda also knows if it is an actual design flaw with the engine or if it is a parts or manufacturing quality control problem.
I can't think of any other service bulletins or warranty that was not based on a specific VIN. Not a single instance for any car manufacture. I do think Honda will eventually issue service bulletins for the warranties based on VINs. There will be a range for VINs for each model.
A service bulletin or warranty extension in the US probably will not apply to the rest of the world the same way. Consumer laws are different in the US. Your consumer laws in your part of the world are totally different. I thought I read on this forum Honda is providing extended warranties in the EU if the car is serviced through Honda dealers. That might be Honda's solution for the EU. Is that warranty extension offered in the UK?
I do think we will learn more about this here in the US in the next few months when Honda starts identifying VINs.
I am hoping the Prelude and its Japanese sourced and built engine is immune.
The other, sadder, explanation for the Prelude exclusion is simply lack of lawsuits. Europe isn't as litigous so may explain why no European warranty extension either.
Every country has different emissions standards.
So this is some possible interesting findings on the issue you may or may not be aware of...(yes, you can take this with a grain of salt as the info came from Gemini after I drilled it for in depth information)
Here is a summary of the findings regarding the 2026 Honda Prelude's exclusion from the head gasket extended warranty:
The Core Reason for Exclusion
  • Separate Supply Chains: Even though the 2026 Honda Prelude shares the identical 2.0-liter hybrid engine architecture used in the Civic and Accord Hybrids, it uses entirely different parts batches.
  • Geographic Demarcation: Every single vehicle impacted by the Technical Service Bulletin (TSB) is built using components from the North American supply chain network. The Prelude is an import built on an isolated network.
Factory and Assembly Locations
CategoryTSB-Impacted Vehicles2026 Honda Prelude
Engine Manufacturing• Anna Engine Plant (Ohio, USA)
• Alliston Engine Plant (Ontario, Canada)
• Honda Powertrain Facilities (Japan)
Vehicle Assembly• U.S. & Canadian Plants (Ohio, Indiana, Ontario)• Yorii Plant (Saitama, Japan)
Global Scope of the Problem
  • North American Issue Only: The TSB is strictly limited to the United States and Canada due to the specific material variances found in North American factories....It is common for the Anna and Alliston Engine plants to share engine parts between facilities based on supply needs
  • No Global Recalls: There are no worldwide TSBs or actions for this engine issue in Japan, Europe, or other international markets. Higher international fuel standards (preventing engine knock) and tighter Japanese factory tolerances mean the imported Prelude does not share the same real-world risks.
The physical designs of these engines are fundamentally identical, but automotive teardowns, metallurgical analyses, and industry data point to several distinct differences between the North American production line and the Japanese supply chain that triggered the issue.
The primary differences that isolate the head gasket failures to North American engines involve the following factors:
1. Open-Deck Block "Slit" Tolerances and Tooling
Modern Honda Earth Dreams engines feature an "open-deck" block design. Between the cylinder walls, there is a tiny, cooling cooling slit designed to allow coolant to flow directly between the combustion chambers to keep temperatures down.
  • The Variation: Automotive teardown experts have noted that the tooling alignment, precision stamping, and casting molds differ slightly between the Anna Engine Plant (Ohio) and Japanese plants.
  • The Impact: Minor microscopic variations in the width or depth of that cooling slit dramatically weaken the thin strip of metal between cylinders two and three. Under intense thermal expansion, the North American blocks can experience tiny deviations that slowly erode the head gasket material over time.
2. Fastener Tensile Strength and Clamping Torque
To hold an aluminum engine block and cylinder head tightly together, manufacturers use torque-to-yield head bolts.
  • The Variation: Regional supply chains mean the Ohio/Ontario plants source their heavy-duty bolts from North American steel fabricators, whereas Japanese engine factories use domestic component vendors.
  • The Impact: Technicians diagnosing these issues have pointed out that variations in factory clamping force or minor bolt stretch ("tensile strength resilience") under heavy engine loads can cause the head to lift a microscopic fraction of a millimeter. When that happens, hyper-pressurized, superheated combustion gases torch the thin gasket material. The Japanese vendor batches have historically shown higher resistance to this load stretch.
3. Regional Fuel Strains and Detonation (Engine Knock)
North American and Japanese market realities treat identical engines very differently due to local fuel conditions.
  • The U.S. and Canada: The massive majority of Civic, Accord, and CR-V owners fill their cars with standard 87 octane fuel. Under high-heat conditions or aggressive acceleration, low-octane fuel can cause micro-detonation (pre-ignition or "knock"). These are essentially tiny shockwaves inside the cylinder that slam against the head and gasket.
  • Japan: Japanese domestic fuel standards skew much higher, ensuring a higher baseline octane rating at the pump. The lack of fuel-induced micro-detonation prevents the secondary physical hammering that accelerates head gasket degradation.
4. Vehicle Layout and Heat Retention
The North American vehicle lineups include platforms built strictly for the regional market, like the massive Honda Accord or heavy CR-V AWD models. The tightly packaged engine bays of these specific models create "hot spots" right behind the engine block where heat is trapped. The 2026 Prelude, being built on a dedicated, sleek sports-coupe architecture in Japan, benefits from completely redesigned front-end airflow and cooling dynamics that lower thermal strain on the block
I don't know if they have different ways of rating petrol between the US and UK, but our fuel E 10 is a minimum of 95 octane, and super E 5 is between 97 and 99 octane I use 95 in mine, which is the recommended fuel.
This certainly would explain why the Preludes have not been included or mentioned as far as possible problems down the line occurring. I feel a little better about the car now.
It is offered as long as it's serviced at a Honda dealer; the warranty then lasts up to 8 years.
Does this mean we should really be using 89 or higher octane to prevent knock?
So, here in the UK we only get the Japan made cars and our octane reading is 95 for the basic stuff. So hopefully, we should be fine.
Hope our American friends have little problem with theirs.
ALL Preludes are Japan made.
I think he may have been referring to the fact that the hybrid Civic is made in the US, hence the possibility of problems with the head gasket parts.
Yes i was and that is getting the prelude mixed in with the "faulty engine" worry. It seems we are all Ok.
I think in Canada there is a TSB which involves a software upgrade to the engine management system. Its posted on one of the CRV sites.
The Preludes for sale in US already have the software fix incorporated. At least mine did, which I bought 3 months ago. They don't need the other TSB they are doing to Civic Hybrids.
Honda must be banking a lot on changing the thermal cycling enough with software fix. Maybe that is why Prelude did not get warranty extended. I think in time Prelude will also get the extended warranty.
What was your production date, what month?
