Regen braking with paddle shifters
Hondo10 8
First hybrid I've ever owned, and I'm honestly blown away. Using the paddle shifters to regen brake and slow the car down is an awesome feeling. Knowing I'm saving wear on my Brembos makes every drive feel rewarding. I've finally gotten the timing down pretty well too.
As for the horsepower complaints, I think people are seriously sleeping on this car. It's quick when you need it to be and incredibly efficient fuel wise. Honda absolutely nailed the balance. I love this car and have zero regrets. Best vehicle purchase I've made in a long time.
First hybrid for me too and have been using the paddles to increase/reset the regen braking especially on downhill slopes.
Going down hilly roads, if using the S+ to shift down "gears" instead of using the brake, does that also regen? A Google search suggests that it does:
Yes, though the amount of regen you can pull in S+ is quite limited. You can confirm by looking at the power flow diagram in the car.
Thanks, will check it out in due time. Have not used S+ yet as it is still in the "break in" period. (Yes, I am old school, and some say modern engines do not need it.)
In S+ mode, as you know, the paddles aren't changing the regen, but you will get regen by applying the brakes - applied gently and it is all regen. Press harder it is regen + disk/pad friction.
I've not tried this.... but I wonder if you can be in S+, paddling up the engine RPMs while also applying the brakes? I bet you can.
Not over thinking it, I would be in S+ mode only for some fun and not thinking about regen! On our Aussie roads I am typically in normal GT mode - thus far...
If you just want to freewheel down a slope, just pull the right-hand paddle towards you; it turns off regen completely as long as you don't touch the throttle.
There is a slight increase in regen at higher RPM though, so you can use S+ to slow for an upcoming corner by shifting up, but it's typically not strong enough. Though yes you can shift to your hearts content while applying the brakes.
