Autocross
GoZoner36
34 day(s)
34 day(s)
Central Oregon
I participated in an autocross event yesterday; my first time. "use traffic cones to make a mini-roadcourse in a parking lot or airport and see who can get the lowest time without hitting any cones or going off course." In my area the autocross courses use deserted ski-area parking lots. The course has hairpins, chicanes, slaloms and sometimes a straight. Because of the layout the top speed is usually less than 60 mph. Lots of safety buffer; nobody runs off course; at most, people spin.
Autocross has loads of car classes - the base class 'street' is limited to 100% stock cars; no modifications allowed other than tires. The classes run from 'AS' to 'HS' (roughly) with AS being the highest performance and HS being the lowest. The 2026 Honda Prelude is classified as GS. (The Civic Si is also GS; the Civic Hybrid is HS; the 2025 Civic Type R is BS; Toyota GR 86 is DS; Mazda MX-5 Miata is CS.). Think of the 'street' class as your daily drivers. There are other classes defined by increasing levels of modifications - suspension, brakes, exhaust, etc. (Here is a 'self classification' tool - it doesn't have 'Prelude Hybrid' yet (https://www.scca-classifier.com/a/index.html))
I was in 'GS' running the stock all-season 'Goodyear Eagle Touring' (threadware 500). The only other car in GS was a 2025 VW Golf GTI using autocross-specific tires - BRIDGESTONE POTENZA RE-71RS (threadware 200). That guy was fast! I was slow. My first run was very slow 71 seconds; my 2nd run I missed a gate (no time); my 5th run I got down to ~65s; then I treaded-water, until my 10th run which was ~64s. Other than that missed gate I didn't hit any cones but I sure was close sometimes. The Golf GTI started under 60s and finished w/ a best of about 55s. I'm 20% off; but it was my very first event and I improved.
Surely it is not the fastest way around the course but I was sliding and squealing around nearly all the bigger corners. Great fun! Slamming on the brakes at the end of straight, turn in, squeal, hit the gas and push and squeal on the exit. Fair to say the power/speed of the car outweighs the stock tires. I'll post a link to the results here once they are available. For all the fun, I may have come in dead last ( :cry: ) on absolute best time but we'll see when the times are scaled for the class.
(I started the day with 9 bars of battery. At the end of the day, I'd run out to 2 bars - not enough regeneration to keep the level up over the 10 runs. I used Sport and S+ but didn't manually 'shift'.)
The leader of the field was an 2015 Alpha Romeo 4C which posted ~54s.
It is a full day event running from 7:30 am to 4pm. Participants are split into two group, A and B. The A group races first while the B group monitors cones and gates for penalties and waves red flags (rarely); the B races while A monitors. Each person gets about 10 runs. About 40 entrants. Highly recommended!
Here are some photos:
GS is my class; 15 is the number I chose (nobody else had it) and N is for 'novice' (for the 1st year of participation).
Here is the Alpha:
This pink 2007 Nissan 350Z was driven by a 18 year old girl; being taught by her dad!
The organizers got me on the course. The engine sound is not mine, it is the car after me, the pink one:
You can see many of the other cars (and judge how slow I was, hah!):
It's cool that you took it to an autocross. I can't do such things with the Prelude because it is my wife's car. I have spent some time in the twisties with it though and it is a lot of fun to drive. You might want to try slowing down to speed up. What I mean is use left foot braking and stay in the throttle. The less speed you scrub off using the brakes the less you will need to make back on the exit of the corners. Momentum is your friend in the Prelude (in any car really, but especially in ones like the Prelude).
My impression is that the Prelude will respond better to an Emerson Fittipaldi approach than to a Ronnie Perterson approach, if that makes sense.
BTW, a BRZ with auto trans and paddle shifters that has had the gearing replaced with the shorter ratio gears that come on the six speed is an absolute terror on an autocross course.
Okay, I didn't come in dead last - 48th of 52 in raw time but when adjusted for class (my time was made with a 'slow' car - GS class) it was 39th of 52. Adjusted time was 52.157s, 7.511s behind first of 44.646s. Not bad at all for a first time (sloppy) driver on stock tires.
Here is the Alpha:
As long as you enjoyed it, that's all that matters, and it did sound like a fun day out. I doubt it will be the last time you have a go; it sounds like the sort of course that would suit the Prelude too.
Unfortunately I caught the sickness and immediately started looking at and thinking about getting a second set of wheels with 'extreme performance summer' tires. Trying to justify the cost: rims, tires, jack, stands, torque wrench, pressure sensor, pressure pump, and brake maintenance.
So far I've fought off the urge...
But, you only live once! Fighting off the urge.
Don’t for get to budget in for a approved helmet and magnetic numbers.
It is addictive. It starts with doing an autocross. Next might be a high performance driving event. I predict you will be signing up for some high performance driving events at local race tracks soon.
Also check out some Gimmick Road Rallyes also. They are fun and a lot easier on your car.
Did your Prelude come with all-seasons?
Note to self: don't forget the helmet
I can't see running on an actual track. The speed is too high; the runs are too long; the boundaries are too close (relative to the speed); the wear is too great; AND, the hybrid battery overheats (noted in another thread and I've seen it reported in some YouTube video too)
Autocross in the 'street' class w/ no modifications (therefore the Honda warranty still applies 🤞 ). Staying in street class requires rims with the same offset - our stock wheels are +60 - almost ALL aftermarket wheels are +40, adding 20mm which looks good but takes you to 'street touring' class. One minute per run, 10+ minutes between runs, enough squealing to be fun, I think.
I did a road rallye many, many years ago. I'll look into it - navigator couldn't be my wife (hah!); maybe my daughter.
Thanks.
Thanks.
I'm thinking of a track day for the BRZ. My wife would never let me do any such thing with her Prelude.
