Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Thanks for the confirmation from a reliable sourceGrok (earlier post) found info from the Civic Hybrid manual. However, the 2026 Prelude manual has the same information, which is copied below.
"The High Voltage battery gradually discharges even if the vehicle is not in use. As a result, if your vehicle is parked for an extended period of time, the battery charge level will become low. Extended periods of time at a low state of charge will shorten battery life. To maintain the battery state of charge, drive your vehicle for more than 30 minutes at least once every three months.
Extreme high temperatures can affect the battery life. You can minimize the effects by parking the vehicle in the shade during the summer."
The systems are not integrated with one another when the vehicle is off. It still uses a DCDC converter style system to transfer power from the HV battery to the 12V system.I was wondering if anyone knew...
I'm leaving for a while, I intend to leave a trickle battery charger on the car.
Will it keep the regular 12v battery charged and the hybrid lithium battery or only the regular 12v battery?
... if youre going away, just start your car every week for 30 mins with your hondalink app! Problemo solved
