Key 2026 Honda Prelude Specifications
Dragoon
Administrator
Staff member
3 day(s)
Key Prelude Specifications
ENGINE
Engine Type
Atkinson In-Line 4-cylinder​
Displacement (cc)
1,993​
Horsepower (SAE net hp @ rpm)
141 @ 6,000​
Torque (SAE net lb.-ft. @ rpm)
134 @ 4,500​
Redline (rpm)
6,250​
Valve Train
16-Valve DOHC Dual-VTC​
Direct Fuel Injection
TWO-MOTOR HYBRID SYSTEM
AC Synchronous Permanent-Magnet Electric Drive Motor (horsepower @ rpm)
181 @ 5,000-6,000​
Torque (lb.-ft. @ rpm)
232 @ 0-2,000​
Total System Horsepower1
200​
DRIVETRAIN
Front-Wheel Drive
Direct Drive Unit
S+ Shift Metal Paddle Shifters
Ratio Range
Electric Motor: 2.455
Lock-up: 0.806​
Reverse
2.455​
Final Drive
3.421​
FUEL
EPA MPG Ratings (City/Highway/Combined)
TBA​
Fuel Tank Capacity (U.S. gal.)
10.6​
Required Fuel
Regular Unleaded​
CHASSIS
Dynamic Drive Modes
4-Mode
Comfort / GT / Sport / Individual​
Honda S+ Shift
Dual-Axis Strut Front Suspension
Multi-Link Rear Suspension
Adaptive Damper System
Variable Ratio Electric Power-Assisted Rack-and-Pinion Steering (EPS)
Stabilizer Bar (mm) (front/rear)
26.5 x 4.6 (tubular) / 18 (solid)​
Steering Wheel Turns, Lock-to-Lock
2.1​
Steering Ratio
11.3​
Agile Handling Assist
Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in.) (front/rear)
13.8 / 12.0​
Electric Servo Brake
BremboTM 2 4-Piston Aluminum Front Brake Calipers
Wheels (in.)
19 x 8.5J gloss black alloys​
Tires
All Season 235/40R19 96V
Summer Tires Available​
EXTERIOR
Wheelbase (in.)
102.6​
Length (in.)
178.4​
Height (in.)
53.4​
Width (in.)
74.0​
Track (in.) (front/rear)
64.0 / 63.5​
INTERIOR
Headroom (in.) (front/rear)
37.2 / 33.1​
Legroom (in.) (front/rear)
42.3 / 32.0​
Shoulder Room (in.) (front/rear)
57.1 / 53.2​
Hiproom (in.) (front/rear)
54.2 / 48.7​
Cargo Volume (cu ft.)3
15.1​
Passenger Volume (cu ft.)
84.6​
WEIGHT
Curb Weight (lbs.)
TBA​
Weight Distribution (%) (front/rear)
TBA​
